CPU Upgrade
I am using a notebook with Core Duo T2250 (1.73Ghz, 533Mhz FSB), chipset 945GM, Integrated VGA 950. I heard that Core Duo T2250 is for Socket M. I used CPU-z and it showed that the socket is 479mpga while the socket shown by PC Wizard is mPGA479M. Will Socket M’s Core 2 Duo CPUs be compatible with my notebook? Thanks
PS: The notebook is 5572ANWXMi of 5570 Series
best thing to do is to ask a store person where ur buying from as to what cpu can be used with your laptop. :slight_smile: good luck
