How many programs do you have running at startup? If you have a lot of programs running in the system tray (bottom right), they can eat up system resources.
Try this:
Click ‘Start’, then ‘Run’.
Type ‘msconfig’
Click on the ‘Startup’ tab.
From there, you can check or uncheck the programs/services you want to start/stop when Windows Starts
Also, some Antivirus software can require alot of resources (especially Norton software yuk).
i unchecked all services on the msconfig and restart…the cpu usage was less than 10% and never above that…so the problem is in the services that are loaded when the windows starts…another problem is that i dont know what service(s) can be causing this large usage
I’d so a scan for spyware, as that can be a problem. I wouldn’t uncheck the services if you don’t know what they are, as some are required for Windows to run properly. Some apps will, by default, install a startup program that’s frequently unnecessary. In XP and 2000, you can access some of these by going to Start–>Start Up Programs. You can safely remove programs from this listing.
NO NO! Don’t uncheck ALL the boxes!!! That could cause major stability issues! What I meant to say was uncheck all the unnessary programs you don’t need.
Here are some common startup programs:
Quicktime - can be disabled
Microsoft Office Quick Starter - can be disabled
Adobe Reader Quickstarter - can be disabled.
You say that now all of the services are unchecked, your CPU isn’t be used as much?
Please list all of the services in the MSCONFIQ ‘startup’ tab, and I can tell you which ones to safely uncheck!
yeah i’ve already unticked msn messenger but still continues using 30/40% of the CPU
i think it can only be two things…can be a windows bug or an hardware problem…if i cant solve this another way, i’ll reinstall the windows, if that doesnt solve the problem i’ll trade the processor for a new one
