Crazy hectic times
I already have a stupid hard drive problem, and now this!
When i turn on the computer, the monitor doesn’t show anything at all, it keeps telling me to check my connection. I keep trying to restart, and then soon this beeping out comes out (it’s the same as the beep at the time when computer boots, but the ones i hear is a BEEEEEEP BEEP BEEP, instead of one quick Beep. I checked the plugs and everything and they’re all the same as ever before when it used to work, can yall help me?
I’m guessing its some sort of power problem so i went to this section of the forum
Na! its the video problem. How is video on ur system? Onboard or Card?
You mean my video card? it’s ati radeon 9600xt, card it is i guess… what? is it messed up or something? cuz thing is 2 days ago i tried to turn the computer on and it worked, but while watching a movie the screen just stopped, and then i can still hear the movie, but none of the keys worked ( almost as if the computer froze), then i tried to restart, and that whole beep thing comes back
Oh, and those beep sounds comes from the CPU, i’m guessing that those are involved with RAM things?
My case seems exact to this one:
Computer fails to start, constant beeping, fan seems to run at full speed
oh and by the way, sometimes there is that normal BEEP the very first time i turn on the computer, and sometimes there’s no beep altogether
Na! that beeps are coming from speaker inside ur PC…
Each beep has different meaning.[link=http://www.computerhope.com/beep.htm]Check Here[/link]
Try this, remove your Video Card and reinsert it back again…
Oh I tried that, and it was the same. I’m really scared that it is the motherboard problem.
I just tried again, the computer works again, and AGAIN, i expect the screen to just shut down all of a sudden and freeze after an hour or 2.
For the beeping (when it does happen), it’s a 1 long, 2 short sequence.
Maybe i’m not setting for the monitor or the hard disks to shut down after a while, maybe something overheated.
The vid card was bought only like 2 years ago (and barely touched by hands), so i don’t really think it has anything to do with that.
Lets start from the beginig…! remove all the extra stuff from your computer. Leave the basics… I mean.. A processor, 1 Ram Stick, 1 HDD, Video Card(If u dont have onboard)… And see how it works…
Also let me know the configurations of ur system!
One long beep + two short beeps could mean:
The graphics card is not plugged in correctly
Make sure the graphics card is sitting tightly in it’s slot.
The graphics card is faulty
Try another graphics card in the computer.
Sorry for not replying to this post for weeks, i had lots of work to do. I tried to switch graphics cards with another computer, yea the original computer worked fine again, but the graphics card that i took out of the original computer worked fine as well on the other computer that i had. Does this narrow down to some problem? My cousin said if it’s not the card it’s gotta be motherboard or the power supply
Have you got another graphics card you can try in your computer?
What are the full specs of your computer? place them in your sig or the My computer area on the big blue bar at the top :slight_smile:
You could try to Reset the Cmos, i dunno if it will help, but its worth a try, some bios settings may have gone bad. Just get a jumper (little black plug thing with 2 pin holes in) and place it on these 2 pins that should be located near the Cmos battery, maybe with your motherboard you may have to take the jumper off, anyway after doing that, turn your compute ron for 5 seconds, and turn it off, take the jumper off, or put it back on whichever way it is for your board. Like i said, i dont know if this will solve your problem, but it’s worth a try.
hey, i tried this thing online, i THINK it’s got all the specs of my computer: now if i can only attach this thing…it’s an html file, can i still attach it on here?
Operating System:
Windows XP Professional Service Pack 2 (build 2600)
Processor :
1.53 gigahertz AMD Athlon XP
128 kilobyte primary memory cache
256 kilobyte secondary memory cache
Drives:
320.06 Gigabytes Usable Hard Drive Capacity
97.93 Gigabytes Hard Drive Free Space
LITE-ON DVDRW LDW-851S [CD-ROM drive]
PM1305O BMN250A SCSI CdRom Device [CD-ROM drive]
ST3320620AS [Hard drive] (320.07 GB) – drive 0, s/n 5QF0CRNV, rev 3.AAC, SMART Status: Healthy
Memory Modules:
768 Megabytes Installed Memory
Slot ‘A0’ has 512 MB
Slot ‘A1’ has 256 MB
Slot ‘A2’ is Empty
Local Drive Volumes:
d: (NTFS on drive 0) 104.86 GB 72.43 GB free
e: (NTFS on drive 0) 106.95 GB 4.26 GB free
f: (NTFS on drive 0) 108.25 GB 21.24 GB free
Printers:
HP DeskJet 712C on LPT1:
Microsoft Office Document Image Writer Driver on Microsoft Document Imaging Writer Port:
Display:This is the video card that i took from another computer
NVIDIA GeForce2 MX/MX 400 (Microsoft Corporation) [Display adapter]
MAG 771FS-s [Monitor] (15.7"vis, s/n FAIU4A037968U, October 2004)
Bus Adapters:
SCSI/RAID Host Controller
Silicon Image SiI 3112 SATARaid Controller
VIA Rev 5 or later USB Universal Host Controller (3x)
VIA USB 2.0 Enhanced Host Controller
Other Devices:
USB Human Interface Device
Hewlett-Packard ScanJet 3400C #2
Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
HID-compliant mouse
USB Root Hub (4x)
HOPE IT HELPS!
Oh and i just switched back the card and it worked fine again…weird…
Exactly…thats what was appearing as a first thought in everybody’s mind…glad to know, things are fine now..~!
Naw, i acctually tried to reinsert it before this card change. Not to make things difficult tho.
