critical!!! help needed!
really need help with a serious issue here… the problem with my pc is that it keeps shutting down automatically by itself whenever i play any game and sometimes even when i am carrying out some heavy memory operations like virus scan or the likes…
i don’t think its a graphic card or RAM insufficiency problem since the games used to work fine in my pc until recently…is it an overheating issue?? if so what should i do???
here are my system specifications…
OS:Microsoft Windows Vista Home Basic
Version:6.0.6001 Service Pack 1 Build 6001
Processor:Intel(R) Pentium(R) D CPU 3.00GHz, 2992 Mhz, 2 Core(s), 2 Logical Processor(s)
Installed Physical Memory (RAM):512 MB
Total Physical Memory:503 MB
Available Physical Memory:137 MB
Total Virtual Memory:1.47 GB
Available Virtual Memory:848 MB
Page File Space:1.00 GB
Display
Name Intel(R) 82945G Express Chipset Family
Adapter Type Intel(R) 82945G Express Chipset Family, Intel Corporation compatible
Adapter Description Intel(R) 82945G Express Chipset Family
Adapter RAM 64.00 MB (67,108,864 bytes)
Resolution 1024 x 768 x 60 hertz
Bits/Pixel 32
please help!!!..
possibly, download Speedfan to be sure, however, it is more likley to be a PSU issue, can you borrow a high quality PSU ?
what is the make & model of your PSU ?
is the gfx onboard (crappy) ?
virtual memory / pagefile / swapfile should be set at double the amount of RAM installed, unless certain software needs more
hi, what are you temps: cpu, northbridge, southbridge? are you overclocking?
have you tried running memtest?
have you got a spare psu to try out?
I’d memtest it first off.
