CRT Monitor Problem
hi guys what’s up.
well i have a problem with my CRT monitor, and i have search a lot of information about how to fix it… but i cant get the solution..
well the problem is that my CRT have lots of horizontal black lines when i play CS at 640… i have heard that the problem is an interference in the monitor, and i have to degauss it…
i did it, i degauss the monitor, and i have turned it off for 8 hours… and it still happen.
i dont know what to do… please guys help me !
i have tried to turn VSync ON, and a lot of things… can be a monitor problem?? i can change it for a new one free… but i prefer to fix it…
this is an image with my problem
http://upload.wikimedia.org/wikipedia/en/0/00/Weaving.jpg
gl guys… i will wait for your answer!!! need backup
and i have this problem too when i have IRC… or a word text… always when the screen is white it goes much stronger…
edit: my monitor is 109B7 Philips and my videocard is nVidia GTX 8800
Could be a variety of problems i’m sorry to say.
Has this happened recently or ever since you got the screen?
Do you have anything magnetic next to your screen or on top of it?
You might be missing some pins in your VGA cable. Try updating your monitor in device manager it might find an update
thanks for the answer scorps65.
this problem happened since the first time i use my monitor, but i have been playing videogames recently so the problem is more important now, and i cant ignore it.
i dont have any magnetic item near the screen, the only thing i have is a cactus(a plant).
i will check de VGA cable now…
can you explain this sentence please? “Try updating your monitor[…]”
thanks you
No problem
OK, click Start > Control panel. In Control Panel look for “Device Manager”. Once in Device Manager you’ll see something like this:
Device Manager
As you can see a user right clicked on his graphics card (radeon) and can select “update driver software”. You need to do the same only w ith your monitor (which is right above “network adapters”)
ok i have already uptated my monitor software, but the problem still happen :(.
i have been reading after lunch and well… i have a printer near the monitor:
http://www.gigabit.com.au/images/productimages/Q8110A.jpg
this printer.
i have read that this printer have a magnet and it can create a magnetic field wich can damage the monitor (im sorry if i cant express properly)
now im going to move the printer and turn off the monitor for 8-10 hours and after that i will try to degauss.
thanks for help, i will post tomorrow!
