CS Source Problem ; Custom Skins
I tried posting this at the official CS forums but no one even replied..
Anyways, I downloaded a custom knife skin for CS Source and downloaded WinRAR, because I was told I needed it to extract the files to the cstrike folder. So I used WinRAR to do that. But when I try to connect to a server or create an offline game with bots, an error message comes up.. something like :
“Server is enforcing consistency to this file..” then it shows the models/weapons/knife.bdl thingy.
I’m really lost.. ANY suggests would be great..
can’t use custom skins in Valve Anti-Cheat servers maybe?
Not all servers have that setting enabled - those using any of the custom skins mods won’t, so you will be able to play on those fine.
There isn’t a lot you can do about it unfortunately, other than search around for a couple of servers that aren’t enforcing ;).
As for your own server, type in the console:
sv_consistency 0
and this will allow you to play on the server with custom skins.
