i´ve finally admited to myself that my DVD burner is dead, people on here will know i´ve been having burner problems for a while, (not a good thing) but does anyone recommend a DVD burner (possibly DL & Lightscribe, as my dead burner only used to support -RW but after a flash, -RW & +RW, but dead is dead, so what does anyone recommend ?
I have one of the following. I have found it to be very good and the price is okay. A good value for money burner, I would say.
eBay.co.uk: SONY BLACK 16X Rewriter Dual Layer DVD±RW Writer 8.5GB (item 140006494627 end time 17-Jul-06 21:15:00 BST)
Any good burner from Pioneer, Sony, Lite-On IT or Plextor will do fine.
Recommendations? The Pioneer DVR-111D or the Sony DRU-820A are excellent burners. Lightscribe isn’t in their feature list, but you will have to choose.
thanks, but, i´ve just being looking, after adding the delivery, i may as well buy a new drive and get a warrenty, plus it doesn´t say the model, which makes me suspicious,
and bought off ebay before and found the stuff is either stolen or knackered
I’ve been very happy with the Pioneer DVR-109 and DVR-111 drives I’ve purchased over the last year.
cheers B ![]()
ordered an Asus DRW-1608P2s cos its DL, +/- RW & £22.05, but mainly cos Asus make decent mobos and it looks as if there trying to break into the RW market, so it will probably be a :swear: good drive,
still apriceate input though !
They’ve been putting out optical drives for a few years, so, yeah, if they’re anything like their motherboards, they should be good products.
cheers B
well i picked that RW for the wrong reasons, but sounds like i made a good purchase, wasn´t aware Asus also made optical drives, but never mind, thanks B
i reckon this is a sik dvd rewriter with dvd ram 12x, dual layer and dvd rw± etc.
ebuyer.com - Components » Optical Drives » DVD-RW Drives » Product details
never heard of that
[QUOTE=““izzy007, post: 80577”]
dvd ram 12x
no itś only 5X
[QUOTE=izzy007, post: 80577”]
yeah
LG GSA-H10NBAL 16x16DVD±RW 12x RAM Dual Layer Writer Black - Bare Drive
GSA-H10N
Model Image
Write/Read Speed (DVD+R) 2.4x, 4x CLV, 8x ZCLV, 12x, 16x PCAV(DVD+R DL) 2.4x, 4x, 6x CLV(DVD-R) 2x, 4x CLV, 8x ZCLV, 16x PCAV (DVD-R DL) 2x, 4x CLV (DVD+RW) 2.4x, 4x CLV, 8x ZCLV (DVD-RW) 1x, 2x, 4x 6x CLV, 2x, 3x ZCLV (Ver.2.2), 3x-5x PCAV (Ver.2.2) (CD-R) 4x, 8x, 16x CLV, 24x, 32x, 40x, 48x ZCLV (CD-RW) 4x, 10x,16x CLV, 24x, 32x ZCLV (High Speed: 10x, Ultra Speed: 16x, 24x, 32x)(CD-ROM) Max 48x(DVD-ROM) Max 16x Write: DVD-R 16x, DVD-R DL 6x, DVD-RW 6x, DVD-RAM 12x DVD+R 16x, DVD+R DL 10x, DVD+RW 8x, CD-R 48x CD-RW 32x Read: CD-R 48x DVD-Rom 16x
i didn´t buy it for DVD RAM, i just wanted to replace my knackered -RW, and figured i may as well get a ± RW, plus it´s a retail not OEM or bare
