I am going to be running two sets of hard drives in my new build. I will have two SATA drives, and two PATA drives. I do NOT want all 4 drives running at the same time, as two of the drives are for xp and two are for vista. I have power splitters for both drives. Question is, can I leave all of the drives plugged into the mobo (DFI) and just disconnect the power so that I can “switch” between the sets of drives? Or do I have to disconnect them from the mobo as well when they are not in use?
Welcome to hardwareforums GreyKiller ![]()
Yes, You can leave devices plugged into the motherboard even if they have no power.
You would be much better off dual-booting than having to remove your case to switch’s OS (I Have tripple booted in the past, from the same hard drive :P). Instead, you just select which OS you want to use from a menu after POST.
[ot]
Vista ![]()
Wouldn’t touch it with a 20ft barge-pole, what do you want it for?
[/ot]
I suspect a keylogger on the main XP hard drives. Right now, I have a vista drive and a pair of xp drives. I have vista installed because I love abuse, and my customers will be buying machines with vista on them soon.
So what I will have is a mobo with sata connectors, the normal pata connectors for the two hard drives and two cd-roms. If I can leave the drives hooked up to the board without supplying power…AND I will hurt niether the drives nor the mobo, I can run both sets without making too much of a mess. I should only have to pull the side off once a day, or, I can actually route the wires to a switch on the front of the case to put power on the proper hard drives.
As long as I can leave all the cables in place, a simple switch should enable me to utilize all four drives easily.
Thanks for your help.
