hi evryone,ive a real prob wit the nvidia geforceFX 5900xt card.when i boot up using the card i see mulitple vertical colorful lines on da monitor.(CRT).its a brand new card. my specs r:
ive installed the latest drivers 66.93. i am currently using a geforce4 mx440 128mb agp8x card.this wox fine.
can anyone tel me wats wrong.all the cables r fine.do i have to do anything wit the registry???
Firstly check the card is properly seated in the motherboard.
Then check the connections and monitor cable.
Then reinstall the latest drivers for your graphics card.
If this doesn’t help, can you either use a different card or try the monitor on another computer? If so, we can narrow it down to being a faulty card, or a faulty monitor.
