display problem
I am XP windows sp2 user.
I have problem with the size of all sofrware icons and words.Also when i brouse in internet the size of images and text is small as well.When i use all software on my pc everything is really small.
My graphic card is NVIDIA Quadro.
Can somebody advise me what to do?How can I make the font and the icons of the software programes bigger.
The simplest solution is to change the resolution of the display. A lower resolution will make those fonts and icons larger however if you do this on a LCD monitor you will suffer from a loss in display quality. This will not be the case with a CRT. I imagine your current resolution will be around the 1024x768 mark. Try 800x600 and see how it is, otherwise you’ll have to go and do some digging in the display applet in control panel. I’m afraid as a non-windows user my experience is rather limited as regards to the configuration options available to you so you’ll have to find your way a little :x:
