I usually find answers to questions I have on-line. I’m never the first one with a problem. But in this case, I’m not even sure how to ask. So… Bare with me.
I have two hdd’s installed. a while back, I installed Vista on one of the drives. Recently I installed Windows 7 on the other drive and had it dual booting. Every time I’d restart my computer, it would ask me which OS I’d like to start up. I wanted this gone. So I went into MSconfig and deleted the vista choice. Now it doesn’t ask anymore… which is good.
But here’s the problem.
I wanted to remove the drive that had vista on it and just use the one with Win 7, but it won’t start up. The only way Win 7 will start up is when both drives are connected. I’m guessing the older vista drive has some kinda of boot thing going on.
Finally, here’s the question:
How do I change it so that the Win 7 HDD has whatever it needs to boot up without the other drive.
I should also point out that when managing the HDD’s within Win 7 it shows the vista drive as Healthy(system, active, primary partition) and the Win 7 drive as Healthy(boot, page file, active, crashdump, primary partition)
I’m guessing I need the win 7 drive to say System as well. How do I do that?
Thanks for any help you can give me.
