Dual display on with two cards?
Does anyone know if it is possible to use two monitors off two cards? I have an AGP GeForce 2 and a PCI TNT2 (ie both nVidia).
I believe the software for the nVidia dual display monitors is called nView, any ideas whether this or another pice of software would work with the two cards I have mentioned, I have no idea whether this is possible.
You can run a dual monitor setup with your two video cards. To save a bit of time explaining it here’s a link to help you get it set up.
I believe NView only works with the GeForce 4 (both MX and Ti’s) line up, so it really wouldn’t do you any good. BTW, this program is included in the 27.xx detonator drivers and above.
Cheers boss!
Apparently WinXP Pro has extra cool duelview stuff, thanks for link, i’m off to tinker : )
EDIT: Up 'til a while ago the answer to this sort of question would be the first thing to come up on google. Anyone else seem to get searches ending in loads of sites trying to flog u stuff?
