Dual Monitor Setup For Extended Display
I have an HP Pro Minitower 3130 with Windows 7 Pro 64bit.
I am trying to setup two LCD monitors for a dual screen (extended display).
The graphics card is an Intel HD graphics. There are two ports, one VGA and one DVI port.
I tried using a VGA splitting, however I was not given an option in the control panel to setup the 2nd monitor this way.
I have also tried plugging one monitor into VGA and one monitor in DVI. This gets both monitors on and working. However, it doesn’t work like an extended display. I can not drag windows from one monitor to the other.
Does anybody know how I can make this work for my machine? Is it compatible or not? Do I need to add a graphics card, if so which one is best for this? Are there any drivers I need to make it work?
Here’s Intel’s own instructions:
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005599.html
It looks like there’s just one thing to check.
Actually, I was a fool. I realized after a few days of thinking about this that I had the monitors reversed. So when I was trying to drag windows I was dragging to the wrong side. Just had to flip the sides!!
