dvd problems
Hi, i trie to copy somthing onto DVD using DVD Decrypter, and i keep getting this message appear, what does it mean, does it mean faulty drive?!?!?!?
Is this when you start to copy or when the burning starts?
I got that message when I was using cheap media. Try different DVDs
Is your DVD r/w New?
Does it read DVD’d?
Is it first time?
Did you tried a second dvd?
Different software…?
[QUOTE=Nic]
Yeah, if it’s doing that with the burn, then, yeah, get some good media. I’ve been happy with TDK DVD-R’s and Sony DVDRW’s (and I would think that Sony DVDR’s are also good quality).
the dvd’s are tesco dvd’s (tesco supermarket lol), but seems like there just re-branded phillips dvd’s, the DVD rw is a nec DVD rw, and seems to get some cycle redundency check errors whern installing stuff off dvd’s aswell.
