dvd writer for emachines 530 pc
I want to upgrade the fitted dvd rom to a dvd writer and would like to keep the appearance the same if possible and want know where I can buy a writer that will fit the pc
Need to know the Model number #
nut you can check here ..
http://www.impactcomputers.com/emachine-parts.html
dear ghostman 1 thanks for your reply unfortunately US eqipment is not the same as european, as emachines HQ have already pointed out to me, also my pc is at least 5/6 years old and does not appear anywhere on the site you sent to me.
regards pond life
Some eMachines are black, some gray, some beige, and some silver. Some have exposed drive bays, others have bezels that cover the drives. If we don’t know which variety you have, we can’t be of much help. That’s why the model is pertinent to the question. Or, you could always take a photograph of the chassis and post it for us.
Ok ! So this is a emachine 530 ? Is there anything else after the 530_..
My guess is that this is 533 mhz or 566 mhz box.. Anyway it is an older box and almost ANY
Beige DVD would work..
