DVI Input problems
I recently replaced my broken 6800GS with a 3650 AGP.
My DV175 doesn’t recieve a signal any more with DVI.
With analog (and an adapter to plug it into my video card), it works.
I plug in my DV172 (with the same cable, I’ve tried multiple ones anyway) with DVI input and it works without any issues.
Does anyone have any ideas? The only one I can think of is that the digital input for my DV175 is broken, which I doubt is the case. (I can’t test with another video card at the moment).
Thanks!
