DVI to VGA converter quality
Hello all,
I have a question about the quality of a DVI to VGA converter. I already ordered a video card, but it doesn’t seem to have a VGA output, but the consultants said it will have a bundled converter which will alow to connect any VGA display.
So here is the question - Will the quality be any worse with that converter than a normal VGA output?
no, it will not, if there is any difference at all using a vga to dvi adapter instead of a direct vga cable then it would not be noticable.
