Hi, I’m new to this forum, I need help with a Epson Stylus CX4600, it has almost full ink, but when I try to print anything, the paper goes through and comes out blank. It’s running a pc with Win Xp Pro, 1 gb RAM, 120 GB HDD, Core 2 Duo, and DVD burner. ANY HELP?
This link will help you out
hope it fixes your problemo ![]()
[Edit]
The link… it has expired,…
Epson® Official Support (GO to Troubleshooting Guide)
Thanks! It said to get new cartridges. I hope it works! ![]()
Security Camera Made From Webcam Internet Camera
I want to buy this adapter that makes any cheap webcam work with the internet like an IP
camera. They say you can plug two webcams into it and then view them from the internet with
out using a computer. The adapter plugs right into your internet with out the use of a
computer. So the big question is, has anyone used this type of thing before and does anyone
know how to use it? Can it work with any webcam or can it only work with some? I want to buy
it from these guys at FREE Shipping Of Wholesale Items China Direct Wholesaler Distributor and I would also like to know if anyone has bought
from them before? This is in thier computer accessories section but the direct link to the
adapter is Wholesale Computer Accessories, Free Shipping, Wholesaler Distributor
I think this is alot cheaper then buying two IP web cameras but I want to learn more about
how it works. Any help would be appreciated ![]()
