Error Loading operating system
I just finished putting my computer together; I started to load my operating system (windows xp-professional) and it stopped formatting my hard drive at 13% so I restarted my computer and now it says Error loading operating system. It won’t let me go any further.:frowning: :frowning: :frowning:
What hard drive is it? I take it you want to reformat and start a fresh install of XP again?
Id get a formatting tool from the manufacturer. They are best in the form of a bottable floppy.
Western Digital Caviar SE WD400JD 40GB 7200 RPM 8MB Cache Serial ATA150 Hard Drive - OEM
Brand Western Digital
Series Caviar SE
Model WD400JD
Performance
Interface Serial ATA150
Capacity 40GB
RPM 7200 RPM
Cache 8MB
Average Seek Time 8.9ms
Average Write Time 10.9ms
Average Latency 4.2ms
Physical Spec
Form Factor 3.5"
Features
Features Fast
Cool Running
Ultra Quiet
SecureConnect
Warranty
Manufacturer Warranty 3-Year
When it arrived it didin’t come with a box just the hard drive wraped in bubble wrap from newegg. brand new
Downloads
Select the top option…
1st Gen Serail ATA WD CaviarSE 7200rpm
Then in the next box select Data Lifegaurd Tools 11.2 for DOS
Its good for formatting, rewriting and backing up your MBR.
[QUOTE=zeus]
Downloads
I don’t have a floppy drive is this still possible without one?
I suppose you could put your new drive in the computer your on now and download the version of Lifeguard tools for windows, install on your working computer and format your new drive that way. (assuming your using windows now?)
Floppy drives are always a good backup for… well things like this! They dont do a bootable version of lifeguard tools for cds.
Which computer doesnt have a floppy? If its just your new computer you could download the lifeguard tools, put on a floppy then put the floppy drive in your new computer just to bootup and format.
[QUOTE=zeus]
Gosh thanks soo much for your help. for some reason when I unpluged my hd and pluged it back in it is working great. and thanks again for your efforts:)
