Preface:
I recently replaced my motherboard in my main system with a Gigabyte GA-G22M-S3L due to several problems including random reboots, faulty RAM slots, and optical drive problems (DMA mode could not be enabled).
My problem:
After replacing my motherboard, I am now getting audio cd autoplay when there is no disc in the drive. Once the device shows it is possessed with this phantom audio cd, I cannot eject the drive and I certainly can’t play the audio cd since there is not truly a disc in the drive. This happens on one or both drives and at varying amounts of time. Sometimes 15 minutes and sometimes 3+ hours.
Error messages:
#dmesg
ide: failed opcode was: unknown
hdb: drive not ready for command
hdb: status error: status=0x48 { DriveReady DataRequest }
#cat /var/log/messages
Aug 9 13:05:08 galactus kernel: hdb: status error: status=0x48 { DriveReady DataRequest }
Aug 9 13:05:08 galactus kernel: ide: failed opcode was: unknown
Aug 9 13:05:10 galactus kernel: hdb: status error: status=0x48 { DriveReady DataRequest }
Aug 9 13:05:10 galactus kernel: ide: failed opcode was: unknown
Aug 9 13:05:12 galactus kernel: hdb: status error: status=0x48 { DriveReady DataRequest }
Aug 9 13:05:12 galactus kernel: ide: failed opcode was: unknown
Ejecting gives no feedback
#eject /dev/hdb
http://img230.imageshack.us/img230/7628/snapshot1tt9.th.png
System Information - Will post additional info as needed
GIGABYTE GA-G33M-S2L
IDE optical drives of varying brand
2.6.23.17.hwf.core2.01
I’ve Tried
[ul]
[li]Tested with Jumper settings at both Master/Slave and Cable Select[/li][li]Replaced the optical drives[/li][li]Replaced IDE cable with brand new cable[/li][li]Rebooted way too many times[/li][/ul]
I know it is a bit lengthy, but I’d rather just give the info up front. Anyone know what’s going on?
