Greetings,
I have a issue, suddenly after starting my computer, the fan increase his sounds like an air conditions, and low too., like the power enter with more energy and the fan has to wheel more faster.
Can someone help me?
Thanks,
Greetings,
Thanks,
Do you know which fan it is ? CPU or System fan ? Open the case up and look to see which one it is.. It probably needs to be replaced..
The Systema Fan it is. The big one.
thanks,
If this is the one on the back, then just replace it.. They make all kinds of fans now days.. Look for one that has a low DBI rating..
Look for one that say low noise reduction.. I had one that was super loud and change it, now can’t even hear it run..
