hi guys,
is there anyway to find out which fonts a program is using, so i know which fonts i need to install on Wine, cos all the ??? dont make much sense to me)
http://img444.imageshack.us/img444/609/wineprobfn9.th.png
also can anyone suggest a easy to use mobile phone (cell phone) software (preferably with a GUI available)
TIA
Edit: obviously trying to run Win software on Wine
[QUOTE=AT]
Wine Fonts
thankies, i was just googling it, but not having much luck
Just a guess, but I think you need msfonts. The debian package is called msttcorefonts.
[QUOTE=kenji]
msttcorefonts
thankies, started dowloading in konsole
nope, didn’t work, putting msttcorefonts in, look
http://img183.imageshack.us/img183/4554/wellphonecy8.th.png
Edit:i will keep trying
If synaptic lets you search for package discriptions, seach for anything this reference to “microsoft”. The debian package search is down, is I can’t look for it. The package in FreeBSD is called msttf. It may also be possible that the package you installed did not install the fonts correctly. Did you restart X after installing? New fonts require a restart of the X server to bring them up. You may even need to add the path to your new fonts in the xorg.conf file under “Paths”.
[QUOTE=kenji]
[/quote]
no just a simulated Wine reboot
[QUOTE=kenji]
[/quote]
will do that then
[QUOTE=kenji]
i’ll try that after restarting X, & if that doesn’t work i’ll fire up synaptic:beer:thanks
