first build - will this work? (any advice?)
Item Unit Price
Intel Core i7-2600K 3.4Ghz 1155pin Boxed CPU $325.0
Gigabyte GA-Z68XP-UD4 DDR3 Intel 1155pin Motherboard $212.0
Kingston DDR3 1600 HyperX Blue 4GB Kit(2Gx2) CL9 $44.0
WD 3.5" Green 2TB WD20EARX SATA3 HDD $83.0
Lite-On SATA DVD RW - 1 Year Warranty $24.0
Coolermaster Extreme Power Plus RS-700 Watt. PSU $87.0
AeroCool Black Hawk Top Docking Front Hotswap $115.0
Microsoft MS Windows 7 Pro 64bit OEM $127.0
Total - $1017.0
it will work. i would recomend not getting a green HD
Just to add to M_Kincy, you should get either a Caviar Blue or a Caviar Black (both from WD of course).
