http://www.ebuyer.com/lists/list/466177
[ul]
[li]Asrock H97M Pro4 Socket 1150 VGA DVI-D HDMI 7.1 CH HD Audio Micro ATX Motherboard [/li][li]Intel Core i5 4690K 3.5GHz Socket 1150 6MB L3 Cache Retail Boxed Processor [/li][li]MSI GTX 750 2GB GDDR5 VGA DVI HDMI PCI-E Graphics Card[/li][li]8GB 1600MHz DDR3 CL10 DIMM (Kit of 2) HyperX Fury Series (RAM I think?)[/li][li]LiteOn iHAS324 24X Internal DVD Writer with SATA - Retail <[/li][li]Toshiba 500GB Solid State Hybrid Drive SSHD [/li][li]Cooler Master CM Force 500 USB 3.0 ATX Case + Elite 500W PSU [/li]
[li]StarTech.com Slim 3.5mm Stereo Audio Cable ( I would like to use these to connect the Desktop to my current Monitor with built in speakers through the ‘audio in’ port thing)[/li][/ul]
What do you guys think?
I will use this as a ‘hybrid’ combo as a workstation and web surfer (will it handle 720 and 1080p HD video?) with tasks such as 3D modelling,rendering video,photo and Audio editing .
What should I expect and what can I do with these specs and what I might struggle with?
Also will all these work together and will I need extra stuff to get things working?
e.g.(A wirelesss adaptor or is it included with the Mobo?)
