kindly refrain from laughing when u read this…I know squiddly about computers…
my floppy drive and my CD rom have stopped working…I have no idea why…I have looked in …device manager…and it says…both devices working properly…any comments or suggestions would be appreciated..
I run Win 98…with 128 ram and a PII…which works quite well apart from the two dead items as described above…
Check your cables inside to make sure they’re all connected properly, especially if you or someone else has messed around inside it recently.
The other thing is that they both might be kaput given that the system isn’t exactly new, and both parts are pretty easy and inexpensive to replace.
Just because the singal is saying the parts are okay doesn’t account for any mechanical failures, which could be the case.
