My computer needs pressing Num lock key to enable num pad, while in previous Dell computer i could type numbers while holding Fn key. Is there any way to make it so that I can just hold the Fn key to type numbers, instead of turning on NumLock every time?
Hi,
This page from Dell website may help you. It talks about the use of the function key with the embedded numeric pad. http://support.dell.com/support/edocs/systems/pmac2cm/en/en_ug/keyboard.htm#figure_1
Try this one
[FONT=Verdana][SIZE=11px][SIZE=12px][FONT=verdana]FN+f11+Scroll lock[/FONT][/SIZE][/SIZE][/FONT]
