For PC Experts...
Hi, I’m buying a new pc and I need some advice, here’s the link -
eBay.co.uk: P4 DUAL CORE 6.8GHZ/512mb GRAPHICS/200GB HDD/1GB DDR2 (item 270024286316 end time 03-Sep-06 20:30:00 BST)
And this is the graphics card I plan on buying shortly after -
eBay.co.uk: GIGABYTE NVIDIA GeForce 7600GS 256MB DDR2 Graphic Card (item 230022882134 end time 08-Sep-06 21:30:00 BST)
The specs seem pretty high and I need to know if I’ll be able to play all the latest games on it. And can someone explain to me what the memory interface (or memory bus I’m not sure) is and how significant it is when it comes to playing games. It says on the first link that the memory interface is “64bit/128bit (effective)” How much does this matter? And is this built into the pc or does it increase alltogether if you upgrade your graphics card? Thanks in advance :slight_smile:
its a gforce 6 mate, no good! (but i see your gonna change it, read on…) dont be fooled it all seems good cause of the layout and the terminology of language oh yes he’s thought this through and caught your eye (and mine at first)
the cpu is a 3.4 (good), nVidia 6200 to be honest is a joke, most likely why its so cheap, will it play the latest games i hear you say. i cant fart loud enough to express my opinion for this scammer. it will but obviously you will need to buy that gpu your gonna buy :good:
i’d swing this one by dude, someone get this guy a job with the advertising industory
all-in-all i suggest you turn around and get this guy to wave your money good-bye obviously its cheap coz of the gpu, however, this guy likes what he’s doin by fooling most people into thinking its the “latest gpu” - this guy does not deserve a penny of your cash and he’s obviously doin well scammin, so dont bother, he’s doin it coz it works, do a little thing called contribution and contribute towards a better future and dont give this guy the satisfaction.
Yeah I know the dude is full of shyt the way he advertises the graphics card, but all I wanna know is, is the comp worth the money?
absulootly not worth the hastle, this guy is using the cheapest components, he’s chosen the cheapest motherboard which is worth no more than 36 quid (roughly $70) the ram is cheap and tacky (slow) this is NOT a good baseline example for a pc upgrade-to-be
this guy obviously doesnt know his stuff (or just doesnt give a shit) coz he clearly says "6.8ghz… 3.4 x 2 (dual core)) it doesnt work that way and almost certinally with that motherboard dual core will not be fully compatible
considering the cheapness of components i dont suppose its worth the money what so ever as i say he’s took the very worst components together to build a P4 3.4GHz pc and charged over-the-odds, do yourself a favor and stay back. contribute, unlike his consumers.
this guy is a scammer. DO NOT BOTHER
