freezing brrrrrrrrrrrr
:eek: hi , im running a train sim programe, and every now an then it freezes,and nothin will work. and i have to re boot
MAXDATA
Service Tag
Express Service Code -
Processor Intel Pentium III processor
Processor Speed 866 MHz
Memory (RAM) 768 MB
Operating System Microsoft Windows XP Professional
Operating System Version 5.1.2600
nvidia geforce mxmx 400 vid card
Make sure the processor isn’t overheating, as that will cause freezing and lockups. You can get [google]MotherboardMonitor[/google] and use that to keep an eye on your CPU. Then get [google]Prime 95[/google] and run the torture test. If you see your CPU temp getting close to 60*C or higher, then it’s a cooling issue with the CPU.
If that’s all clear, get ahold of [google]Memtest 86[/google] and use that to check your memory for errors.
hi there im trying to install mother/b mon. but i dont know which board im using, help :mad:
Goto our “Download Zone” (Top Right of Forums) and go to the “System Information” section, and download “Aidaware32” this will tell you your motherboard and model.
thanks big b downloaded the mother/b mon, and running at 54deg approx, cant seem to find a 95 thingy download..sorry about double thread :sick:
:o thanks procalx downloaded aide good job…well done sorry to u 2
