Pretty good stuff, heatspreaders are a nice addition. The timings aren’t too good but latency isn’t everything. If you don’t mind spending a little extra two of these would serve you a little better: http://www.newegg.com/Product/Product.asp?Item=N82E16820231023
G.Skill is a very respected company and is also known for excellent overclocking potential. Either way you’ll be happy.
[QUOTE=Big B]
How many amps does that power supply have on the 12V rail? While the 7800GTX isn’t quite as power-hungry as the 6800 Ultra, most of the ThermalTake units have around 18A on the 12V rails, and that might be a little tight between the video card and cpu as they both run off the 12V line.
If you need to, I know Newegg has an Enermax 460W power supply with around 25A on the 12V rail for around $52+ shipping.
Hey Big B, should i get a dual 12V or stick with one 12V that has a higher ampage , say between 25-36? Because i saw an Enermax power supply that had dual 12v but both at 18a, what’s better?
http://www.newegg.com/Product/Product.asp?Item=N82E16817103458 (dual)
http://www.newegg.com/Product/Product.asp?Item=N82E16817103464 (one)
