You may need to start the fans off at their normal voltage to get them started otherwise they may not start, as for the value of the resistor it depends on what voltage you need to get them to run at 60rpm, I’m not sure of that.
Formula for working out resistance is
R=V/I
Where
V=Potential Difference in Volts
I=Current in Amps
R=Resistance in Ohms
