I ordered GA-EP45-DS3R Mobo should be coming in tommorrow
Infact I bought a bunch of stuff.. sigh ok ill just go over everything I bought. For my new build.
CPU: Intel E8400 (169.99)
Newegg.com - Intel Core 2 Duo E8400 Wolfdale 3.0GHz 6MB L2 Cache LGA 775 65W Dual-Core Processor - Processors - Desktops
GPU: ATI 4850 (184.99)
Newegg.com - VisionTek 900241 Radeon HD 4850 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Desktop Graphics / Video Cards
RAM: 4GB DDR2 800 (90.00)
Newegg.com - CORSAIR 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Desktop Memory
Mobo: Gigabyte GA-EP45-DS3R (134.99)
Newegg.com - GIGABYTE GA-EP45-DS3R LGA 775 Intel P45 ATX Intel Motherboard - Intel Motherboards
PSU: Corsair HX520 (114.99)
Newegg.com - CORSAIR CMPSU-520HX 520W ATX12V v2.2 and EPS12V 2.91 SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC Power Supply - Power Supplies
HD: 500-750 GB Sata II, 7200 RPM (99.99)
Newegg.com - Seagate Barracuda ES.2 ST3500320NS 500GB 7200 RPM 32MB Cache SATA 3.0Gb/s Hard Drive - Internal Hard Drives
But really I have a few questions since I am a begginner. I know all reviews say this MOBO needs the bios flashed.. If i go to gigabytes website and download the f9bios.exe file and run it.. is that considered flashing it? Or do I need to do something else to flash the bios to a newer version?
thats really all i needed to know is about the bios.. and maybe what you think of my build I have coming in tommorrow? Btw it will be going into a antec 900 case.
