Geforce 2 Mx44o
All i want to know is the voltage this card runs on i have serched on this form and not found anything only stock voltage what ever that is i need to know as my mother board will not run anything higher than 1.5 v
AGP 2X runs 3.3V, AGP 4X runs 1.5V and AGP 8X runs 0.8V!
Which interface does it use?
All GeForce 2’s should be AGP 2x/4x compatible, although some of the GF2MX’s were re-released with AGP 8x support added in (worthless since AGP 8x conincides with AGP 4x standards). If you’ve only got 1.5V for the AGP slot, you’ve probably got an Intel i800 series chipset (i815, i820 or i845).
i have installed it to a asrock k7vt4a board what i was after the voltage the graphics card uses the board say only use a graphics card that uses 1.5v max
