Ok, I have bought absolutely everything I need to build my new computer. This will be the first time (from scratch) that I have ever attempted this and have just a couple of questions I need to ask:
Heatsink Paste - Do I actually need it when installing my processor into my motherboard and what does it do? (It’s a P4 CPU and a Gigabyte 915P GA-8I915P Duo Pro motherboard). There is no mention of it in the P4 instructions manual, however, it is mentioned in the motherboard instructions when installing.
Electrostatic discharge - I have never really took this into account before when upgrading my previous PC, however would it be entirely necessary if I bought an ESD band or something? Or are there special precautions I should follow? I have asked others who do much PC modifying etc and none have really come across it before. What do you guys think?
Thermal Paste = Essential, Arctic Silver 5 is the best IMHO but other like Ceramique. You spread a paper thin layer over your CPU die before putting the Heatsink on, the Paste assists thermal transfer between the 2 by filling the micro gaps that having not-perfectally flat serfaces cause (you will never get the surfaces perfectally flat…)
ESD = Wrist bands are good if you buy a good qulity one, also if you dont want to just touch an exposed metal part of the case every minute or so to get rid of any static build-up you may have.
On building your rig if you want any-help we are here but here are a few sites worth a look at… http://www.pcmech.com/byopc/ http://www.buildyourowncomputer.net/learntobuild.html http://www.buildyourown.org.uk/
Hope this helps
Matt (another one…w00t!)
You don’t necessarily need thermal paste, sometimes the heatsinks come with a thermal pad, just gotta take a look. If it doesn’t, then YES you MUST put it on yourself, but not lots. As for the electrostatic discharge, I wouldn’t worry, I’ve built quite a few systems and I have yet to fry anything this way. Best of luck to you. It’s the best feeling when you build your first PC and it works
Thanks for the prompt replies! I have actually just looked in my CPU box now and noticed a small square strip on the bottom of the CPU fan. Could this be the heatsink paste? I could get a picture if thats any help (wouldnt want to buy some then find out I dont need it) but it is an official P4 fan, not OEM.
If you don’t want to buy a wrist strap, you can touch your PSU before you handle the components. Just make sure that the PSU is plugged into the mains but also switched off at the back so its still earthed.
Glad we could help! :good:
Oh and StimpE, thermal paste isn’t essential but when it comes down to it I’d much rather use paste than a pad, I dont think pads can match the mighty cooling power of AS5…(makes Arctic Silver 5 sound like a superhero…heh)
Hi, its me again. Just run into another minor problem. I just need a little help regarding connecting my motherboard to the case. Theres a picture below. On my motherboard there are 6 holes (3 along the top, 3 along the middle, and 3 along the bottom), all of which would easily screw into the case (the holes are slightly raised) and fit the I/O plate. Although, after reading info on some sites, is there any special precautions i should take? The motherboard seems to almost be touching the case if I screwed it in, but it would fit the I/O. Am I worrying too much about nothing? lol
Only 3?!
You’ll need more than that (you may have got some with your motherboard), you screw the standoffs into the case where the holes are for the motherboard (there are different holes for different orientations and types of motherboards) and then place the motherboard in making sure the holes line up with the holes in the standoffs, then you screw the motherboard to the standoffs, this stops the motherboard from making contact with the case and shorting out.
[QUOTE=Matt555]
It gets the job done if you don’t plan on overclocking the hell out of your core, but if you think you’ll have high temps for some reason, it won’t hurt to throw on some AS5. I think he said it’s his first system, so removing the old thermal pad and replacing it with AS5 could be a difficult task for a beginner, anywho, good luck with your build.
Thanks for the sites Matt. Using the only 3 standoffs I have (none in the motherboard box im afraid), I have installed my motherboard with yet another problem. The I/O panel doesnt fit with the board installed. Does this really matter? The picture below shows how it looks. Would you say the board seems a little too close to the case on the left? But you would recommend more standoffs yeah?
Right, final post now as I am getting tired already lol. I have tried putting my PCI-E graphics card in and there is simply no room in the case for it. I think its now obvious to say I need a bigger case. The one I have here is a Casecom KG-188. It says it is compatible with ATX (my board) but it is a miditower and also compatible with micro ATX (enuff said).
…Recommendations for an affordable ATX case??? lol! Must be black.
