[QUOTE=jonbenge]
I have a few questions regarding dual processor motherboard rigs.
Q1. You aren’t forced to use 2 processors are you? You can use one processor and leave the other slot/socket empty.
[/quote]
Yes. Some motherboards, particularly with the Slot 1 or 2 boards, required a terminator card in the empty slot, but that was included if it was required.
Q2. I believe you can’t use two Celerons? They must be Pentiums?
For the most part. The Celeron’s up to 533MHz were SMP capable. The 533A Celeron was a new core that Intel removed (or disabled) the SMP capabilities from. Abit’s BP6 was one of a few SMP motherboards that could natively run Celeron’s in SMP, and probably the main reason why Intel nixed Celeron SMP.
Q3. Do the two CPU’s have to be matched in speed and FSB. Can i install one 700MHz and one 800Mhz for example?
Yes. As long as they have the same FSB and multiplier, you’re okay. While a few people have been able to run two separate speed CPU’s at their varied speeds, there tended to be a lot of stability issues, so even if you were successful in making the thing work, good luck finding an OS that won’t barf on you.
Q4. Which Operating Systems support dual processors? I believe Windows NT4.0, Windows 2000 Pro, Windows XP Professional and Server 2003 do?
Yup. NT4, all Win2k varieties, XP Pro, and Server (any server version of an NT-based Windows OS will support dual- or more processors).
Also, most Unix-based OS’s will (*BSD, Linux).
Q5. Does software have to be written to specifically make use of dual processors, or does the OS handle that automatically? What I mean is will i actually notice more power, or only with specific software, ie server software.
If the software is written to take advantage of 2 or more processors, then, yes, it will automatically do so if the need arises. Otherwise, the OS will do load-balancing to divvy up the work. So you could run some video encoding and play some Doom 3 while you wait, and not suffer performance (assuming you’ve got a decent setup—not a pair of Celeron 500’s and a GeForce 2MX).
Q6. Lets say I open MS Word and MS Excel at the same time. Will the job of loading Word be sent to one processor and Excel the other? Or do they share the same workload?
Typically, the first processor will be loaded up, but this depends on the size of the load and the OS.
Since you’re looking and dual processors, you might want to hit up 2CPU and read up some of their articles and stickies in their forums.
