Hi
I have bought a second hand Mitsubishi (NEC) Diamond Plus 91 monitor and it is driven by the NFL 9905 driver on Windows XP. The monitors geometry has been poorly set up by the previous owner and I am trying to reset the monitor to it`s default factory settings without any success. I cannot do this, as when I use the Geometry Reset function it complains “geometry reset - user timing - cannot be reset”. Upon further investigation the monitors settings are set to 56.5 khz @ 70.1 hz User -11.
If anyone has any thoughts on this matter I would be very grateful as it is a good monitor otherwise. I have also looked at the NEC website for clues but no luck.
TIA
