There is a PC that I am planning to build, it the Power Supply that I included in the project okay? Because I might do 2 graphic cards, that’s why I am asking if the power supply have enough power or should I take more wattage?
Hi,
I dont see your list of hardware in the post, however if you fill out this wattage calculator from Asus, it should give you a good estimation of the wattage for a power supply that will work for you ![]()
Post your build that way we can help you out better.
Need more info, before we can help you..
The thread started in 2011. It’s 5 years later, folks.
