Hi Buddies..
hope u r doing good..
i m hoping to be told the actual solution of the following problem that has been embarrassing me for the last few days..
The problem is:
whenever i turn my PC on, it doesn’t display, all the lights of board and casing get to turn on, but the display doesn’t appear unless i change my DVI cable from gpu’s first port to its second port, then turning the pc off and on once & twice, pc starts working fine and shows display perfectly.. my gpu drivers are upto date..
can u guide me how i can solve this issue.. and which part is creating this problem ?? gpu ? mobo ? rams ? psu ? any software? driver ? windows ?
My PC specs are:
Core i3 540 processor
Asus ph755-v mobo
2x1tb seagate hard disks barracuda
4gb kingston KVR rams 1333mhz
Sparkle Calibre GTX 460 graphi card
HP dvd super combo
Corsair vx550w power supply
Asus vento ta m-21 casing..
Windows 7 64 bit OS
ESET nod 32 business edition..
Note: i started getting this problem recently.. otherwise my pc was working fine..
please help me..
thx ![]()
Regards,
