Here’s another two, the first makes a nice desktop while the second serves no practical purpose, more of an experiment.
http://www.hardwareforums.com/attachment.php?attachmentid=611&stc=1
http://www.hardwareforums.com/attachment.php?attachmentid=612&stc=1
Thought I’d bring back the ol’ matrix thing:
http://img209.echo.cx/img209/116/followthewhiterabbit23tf.th.gif
This will probably take a while for us dial-up users to load but there’s a very small bonus at the end. If you want Waffles you can put this under my work examples section in my staff profile, it’s up to you.
exfoliate, could you size down your sig a bit? It’s pretty big for a sig, width isn’t a problem just the height but it looks damn cool
Thanks dude, hows the height now? (I’m assuming you’re refering to the icy one, not the matrix one as I’m not using it, even thought it’s bigger).
Nic
April 12, 2005, 9:33pm
25
My icey using Exfoliates tut
Nice tut m8
Also I made this mad red thing when fiddling with filters, I think it looks cool
lawl filters XD. Exfoliate, looks good now
Looks awesome Nic, I think it came out much better than mine, the firey one is also very well done up, pretty slick stuff.
Waffle
April 13, 2005, 6:25pm
28
Yeh sig size is much better - the limit is 600x200 ideally, so your sig is fine now
oh loving the new avatar
remember- any new material/tuts/brushes/photos you have, send em in.
I’ll have that submission form working tonight, I hope.
This took about 3.5-4 hrs. to actually get to work how I wanted but here it is, convincing huh?
http://img231.echo.cx/img231/5458/awesomesun5dz.gif
Then there’s this Devil May Cry thing that’s just a little too big to become a sig as much as I want it to be one. It took about 2 hours or so, origionally I didn’t have the colors inverted but I think it looks better this way.
http://img76.echo.cx/img76/769/32dantestilllooksgood4dj.gif
Waffle
April 16, 2005, 9:14am
31
the dante is very, very nice. but yeah its too big for a sig, but just showing off, don’t worry about it.
awesome.
Nic
April 16, 2005, 10:18am
32
Loving the sun and the sig, you get much better with every piece you produce.
Thanks you two, glad you like 'em. It really does make a difference when I use some adjustment/fill layers and tweak the layer styles.
I appoligize for pretty much (inadvertantly) stealing your idea Waffles but here’s something I whipped out a hour ago:
http://img260.echo.cx/img260/2945/halflife2sig5uz.gif
Waffle
April 19, 2005, 9:28am
35
sweeeet…
can i suggest you delete the “black” background layer, so that the sig is transparent there, it would look a lot slicker
Sure, I’ll try that, oh, and HALO is very cool, the color scheme is perfect. How’d you get the border though?
Waffle
April 19, 2005, 4:13pm
37
some one hasn’t checked shattered realms today have they
Oh, yeah, just got out of bed. Ah, and how do I get the canvas bit to become transparent, use the rectangle tool to select the top bit and make a really low opacity white color?
Waffle
April 19, 2005, 4:24pm
39
I assume you mean the ‘background’ layer?
You can either double click it to make it into a normal layer, then grab the rectangle marquee, drag over the white and hit delete.
or you can go File>>New>>and specifiy “transparent background”.
Ergh, it doesn’t want to leave…I thought I did it right?
