I am experiencing bad framerate using the powercolor x1950 pro AC2
Things I’ve done:
Tried old ATI drivers recommended with the box given
Tried ATI catalyst 8.1
Rebuilt OS just encase of old drivers conflicting
checked if all fans are working. All are
checked hardrive. All seemed fine
Got a new powersuply. An Arctic 600w with plenty of Amps on the rails
Most drivers are up-to-date with the system .
System specs:
Intel pentium D 3.2ghz
Maxtor 7200rpm 150gb
2gb pc5300 memory
ASus P5VD2-MX SE motherboard
I’m currently using OMEGA drivers. They seem to have gotten rid of the choppiness, but the terrible frames remain.
I’ve done CPUz and i have found out that my <Link hidden. Register for free to see this link!> seems to be going from 2.4ghz to 3.2ghz continuously. I have purchased paste for my heatsink and will clean that & reattach it later on.
Games i play really do suck in frames. I’ve tested IL2 sturmovik and Oblivion and both are very similar in frames. If i lower the settings i get a boost of maybe 4 frames
which are normally 14-20 frames MAX, but if i face a wall i get about 60
resolution : 1024 x 768
If you require more information, I’ll be happy to add more details if necessary .
PS. I’ve RMA they old card for a new one and the problem still persists. My guess that it might be CPU or motherboard related. Also, i have no sorts of malware, viruses on my system ![]()
Thanks for reading
