Please, if you’re a technician/professional/skilled user, take a look at my story, as I’ve exhausted what I can figure out on my own. (Also, if I should be putting the post somewhere else, let me know.)
I built my own power machine about a year and a half ago, and I’ve done nothing but suffer with it. I’ll try to keep the description of the issues as brief as I can, but there’s a lot of backstory/specific issues.
First, I’m an A+ certified tech, and I built the machine myself, so I’ve done a bunch of investigating already myself. I’ve become convinced the motherboard has to be the problem, but I’ve been burned multiple times, and I’d really like to be certain before I shell out another 200+ bucks.
Here’s the system specs:
Gigabyte DQ6-X48 mobo
2 x 2 GB OCZ Platinum PC3-10666 ram (ie DDR3-1333) back at stock speeds
Intel Core 2 QX9450 2.66Ghz, was at 3.40Ghz, back at stock
Radeon 4870 1GB video card (was previously nVidia 9600GT)
Sound Blaster X-Fi Elite Pro soundcard
2 x 750 GB WD Sata II drives in Raid 1 (part of the story)
1 x 250 GB IDE WD
1 x 200 GB IDE Seagate
LG Blu-ray/HD-DVD reader/dvd burner
2nd DVD/CD burner
Corsair TX650W power supply
CoolerMaster Cosmos Case with 4x 120mm fans
Legit Windows XP Pro Service Pack 3 with all updates
Latest update of DirectX 9 installed
Tests I’ve done on my own:
CPU Burn-in x 4 - Passed with flying colors
MemTest86 - Passed all tests twice
Video card stability test - immediate failure with both ATi and nVidia cards
HDD Health on drives - All drives in excellent condition
Now to the problems. First, the two 750GB drives used to be set up in a raid 0 array, instead of raid 1. Several months back, my machine did a hard freeze in the middle of watching a blu-ray movie, I heard the pc speaker beep once, and rebooting the machine resulted in the raid 0 array showing failed.
I thought one of the hard drives had failed. After testing in another machine, I learned both hard drives still worked fine, and HDD health reported them as in excellent condition.
I tried reinstalling windows on the drives in raid 0, using the raid boot disc on the Intel ICHR9 raid controller, and windows blue screened during installation (more than once.) Using the gigabyte raid controller (the motherboard has two sata/raid controllers, intel having 6 ports and gigabyte having 2) which is exactly what I was using before with the drives when the raid 0 array failed, I was able to install windows without problems, resulting in the current raid 1 setup.
Since then I’ve had repeated crashes, identical to the first (always under load on the hard drives from uTorrent, or load on the video card from a game or something), where my system will hard freeze, sometimes with a beep and sometimes not. These last few crashes resulted in blue screens, with windows reporting a problem with either a non-specific device driver error, or the latest time, a display driver error.
Because I’d also been having some non-fatal, but noticeable issues with with video (specifically, any time I run a game in 1600x1200 resolution (and only this resolution) I will get green speckles that flicker along the edges of polygons and spread over the screen. Note that running a game in 1920 x 1200 (or any other) resolution does not result in this speckling, to my great confusion.
But even still, with the device driver/display driver blue screen messages, the in-game distortion and the fact that I got the 9600GT card cheaply and the PCB on it is a little warped, I became convinced it was the video card. So I figured I’d fix the problem and upgrade the card at the same time, getting the Radeon 4870. I uninstalled the old drivers, used driver cleaner in safe mode to clean everything out and then installed the ati card, downloading catalyst 9.3 drivers, not using the ones on the disc.
Playing a game in 1600x1200 resolution still results in the exact same green speckling all over the screen, (while 1920x1200 still does not) and it still freezes quickly, even playing something as old as Diablo II. The only positive, is that Ati’s VPU recover seems to help to some degree, because now when it crashes, I don’t have to reboot, the driver just resets.
So, if both video cards produce the same results, that means it’s the motherboard, right? I can’t see what else it could be, save maybe the power supply, but though the radeon 4870 draws serious watts, the 9600GT didn’t, and this was happening well before the radeon was installed. 650W (and it was not a cheap model) should be plenty for a single video card, yes?
What I want badly to know is whether I can be certain it’s a bad motherboard, because if that’s the case, I’ll just replace it and rebuild the machine (even though I really loved the features the board offered and you can’t even buy a DQ6-X48 anymore.)
Is there something I’m missing though? If I replace the motherboard for $240 for like an Asus X48 model and I still have problems I might go bald at an exceptionally young age.
