I was using my computer today. everything was normal
until I opened windows exploer for the X time in the day.
This time it had a delay to load and the Harddisk did a click sound
like if it was stopped then started again, then WinExplorer loaded, and it occured like 2 or 3 more times.
I turned off my computer because i got scared, because i have heard
this sound before in other comps and then the HD dies a few days later.
A lot of ppl call to this sound the click of the death.
I turned my comp on again 30 min later and windows loaded without any problem. But then i opened nero burning rom it happened once and now it’s working fine. I’m not doing any heavy load work.
Im doing tons of backup CDs now, and everything is going fine. No more weird clicks.
Im using a maxtor 120gb model 6Y120M0
Is there any chance that my HD is dying or it was just a random click?
thats weird,i thought maxtor was a good HDD..i actually have a quantum fireball 40g HDD for about 4 or 5 years now..its quite good id say n i also have a western digital HDD..i know WD is a good hdd..
[QUOTE=ninja fetus]
maxtor doesn’t have a very good reputation with hard drive life. That meaning, they often die. That clicking sound is your hard drive dying slowl.y
hmm on the subject of clicking, mine has been making a clicking noise when it accesses stuff, it never used to in my old case (that had rubber vibration dampeners) and it does in this one (this case doesnt) i’m sure my HDD isnt on the way out as i’ve had no problems, but it may be so i may get a new HD soon…hmm :ohah:
some maxtors are fine. id compare pc part to groceries. some brands just last longer than others. theres always that gallon of milk that goes bad 2 days after you get it home regaurdless of brand. then theres the scary rolls you find 2 years later that are still as soft as when you bought them.. its hit or miss really. a lot of different things affect hard drive life. but yes maxtor has been known to have a few problems. then again i cant think of many brands that havent had a few problems. i wouldnt go playing favorites or blacklisting a brand just because some people had some problems.
that clicking noise though… probably it dying. is it at normal intervals or just random clicks, or does it only do it when you access something on the drive? if it clicks on a regualr basis..90% sure its gonne crash soon..start looking around. hd’s are cheap as dirt right now. if you get a new one before this dies you can possibly prevent some data loss. just install and copy over the files. lots of programs out there to help you as well with the file transfer.norton ghost i believe. ive never worked with it myself but i hear good things. also keep in mind that clicking noise may not mean impending doom. ive got an old 256mb drive thats done that since 1994.. last i checked(a few months ago) it still works. hope this helps ya.
yeah i honestly dont think its my HDD dying, although it may be, there isnt anything to be suggesting dying apart from the noise and i think it may just be vibrations…hmm interesting, might have to look into this puts on a detective hat and trenchcoat, walks out of door in a stylish yet important way
[QUOTE=aji1217]
it did like 3 or 4 times in a row yesterday . Then i turned off my comp
and turned back on and did it one more time when i opened Nero.
I did a powermax (maxtor HD’s testing program) full test yesterday and it said everything was fine.
I’m using it right now and everything has gone just fine but im still concerned about it.
I dont want to spend $100 bucks for nothing, since you mentioned you have a drive clicking since 1994 and it still works
in your personal experience what do you think is worth buying?? maxtor again, seagate, WD, samsumg???
[QUOTE=oilisab]
honestly the way i shop is i find a product i like… go to google and type in the products name, followed by the word review. i look through at a minimum of 2 pc site reviews(ie something along this line- TwistedMods ) and try to find as many customer reviews as possible..they are almost all out there. thats a real good way to see hard numbers on performance and what all you get with the package, as well as any little quirks it has(site reviews are great for that) and see how many customers had problems with there products..as long as your not buying BUBBAJOES 200GB hawrd dryve, you should be ok i think. just do your homework first.
and im not saying that the drive clicking means your gonna be a-ok either..if youve got things on your hd you need to save, id get a backup. if not you can find a nice one you like now, write it down somewhere(not on your desktop or ie favorites please) and if/when it does die you just buy your new one. your call really.
When the drive starts to make clicking noises along with delays, its definately not good. You’re lucky to be able to back up, as when it happened to me it just died. Sometimes its just bad luck.
[QUOTE=ninja fetus]
maxtor uses a different bearing design than WD and Seagate that runs hotter and shorter hard drive life.
pretty sure the bearing problem was resolved a while ago(few years ago..). I have a friend who almost lost his hand to a WD drive at work.. one of the old monster drives..its like a 5"x5"x8" box…somehow it locked up and the platter cut out of the plastic drive housing and flew accross the room.. we only saw the aftermath..(pretty sure he dropped it while it was on.. still scary though..nice dent in the wall about 20 feet away.) but ive got a western digital in my comp now..
everyones got different opinions and views on hardware.. just postin mine…i only blacklist intel and windows ME..
i had my samsung clicking too, its not broken isnt it? this occurs after i broke my cpu pin then i formatted my main drive but then this one wasnt a system drive, i kept files in it only..
