My hard disk and cd-rom does not show-up in BIOS and does not boot.I changed the hard disk to other PC where it works as slave and I am able to boot. But when I remove the master hard disk the slave disk neither shows-up in the BIOS nor boots.Need a solution to fix this.
If you removed the Master , Did you reset the slave to Master when you hooked it up ? And install it on the First lead ?
Failure in hard disk detecting may be because of several ways like system BIOS problem ,jumper setting , Boot order sequence, hard disk slot problem etc. You may now check these points and check your supply as well as.
Try resetting the slave drive to the main drive of your PC or adjust the jumper settings maybe that will help…
