I am unable to low level format my both the drives.
ST320413A 20 GB
ST36421A 6.4 GB
Both my drives have bad sectors and i want to remove them. the best way to do it is to Low Level Format the disk(b’coz format/c/u didn’t worked, that i tried).I’ve DM ver 5.0,9.5 and 9.56a,and i’ve tried every ver. but they show “Low Level format completed successfully.” but when i re-start my comp. i find all of my partitions,dirs. and files as it is. i’ve used fdisk/mbr and try to low level format my disks but same problem.
Thanks in adv.
I’ve tried that also. I’ve also downloaded DiskWizard 2002 and tried to Low-Level Format my HDDs but couldn’t found the Low-Level Format option in it(neither Zero Fill Drive was there).
In one of the options, I selected was in Mantinence–>Partitioning and Formatting Options–>Create new Partition.
That upto some extent solve my prob. as I m able to recover my 20Gb HDD. and on 6.4 GB, after doing the same tasks, it showed me a partition of 6.0GB, when I tried to format that partition thr. WinXP. A message popuped windows can’t format this drive.
