Hard drive prob
Hey
I copied over about 2 gigs of files from one drive to another on a partitioned drive. The files copied over fine but the memory from the original partition is the same whilst the other is 2 gigs less. I cut and pasted these files. Can you help me free up this memory? Cheers
Check the recycle bin. Failing that, do a search for one of the files to see if they’re still there.
use something like this to synchronize the file & folder / directory structure
BTW: theres probably a freeware one on the net or just use it fror upto 30 days, as you will probably only use it once
