I have a pentium 4, 2.8ghz pc. I have a problem where my hard drive died and I have had to replace it with another one. When I go to install windows xp it allows me to format the hard drive but then just re-boots rather than installing xp, and goes back to the initial stage. I have tried it with two spare hard drives that I have and the same thing happens. These are older drives and not SATA drives as don’t have any of those. Any advice would be gratefully received.
[QUOTE=GRECIAN2006]
are you sure it is actually formatting the drive or is it creating an active partition on the HDD, cos you must reboot XP before you can format the partition to install XP on
I don’t think so, it appears to going back to the stage when you first boot with xp disk. I will check though and see
Maybe you should pre-format the drive and simply point windows installation to the prepared partition(s).
How many HDD’s do you have in your PC?
If you need to recover data, get “Recover my Data”, I’ve tried them all, and this one works the best; was actually rated the 2nd best on toptenreviews.com the software that got the number one position boggles my mine as to why it was number one, the number one software they had for recovering data was prolly one of the worst ones I’ve tried
R U sure that he wants to recover the data:rolleyes:?
yea, i didnt really read the thread, HD problems and lost data relate, so i thought I would just put that one in; i prolly should have made it an off-topic thread; like this one; ehh oh well; too lazy
Thanks for the advice guys havn’t had time to try yet but will post with results
