I’m using a Catalina sound card (which is admittedly discontinued) and not getting any audio out of it when Flash player is involved. Java audio (e.g. Runescape) works just fine, Media opened in the browsers (both Internet Explorer and Firefox) is okay (Quicktime and WMV/WMA), but when I try and watch a flash video with sound, the video is okay, but the sound is noticeably absent. I have the latest drivers, or atleast the ones that I found on their website, so, if anyone could help, that would be great. Thanks in advance.
update:
I managed to solve this finally… Turns out it was FFDSHOW that was causing the trouble… This is where I found the fix to it…
yea… no sound comes out of the speakers at any rate, but the video is excellent. on a rather (to me) weird note, youtube videos online don’t play audio, but when downloaded and viewed with the player, I can hear them just fine.
Usually these problems occurs due to the missing codecs but as u said that u have got em already so dont know wat exactly the problem is..
Can u check in the Device Manager if there is anyting with yellow traingle?
Oh then try this…Right Click on the Sound drivers and uninstall them. Restart your computer. Your computer will detect your sound card and will ask u to install drivers… Then go through that wizard and install the drivers again.. See if it works :unsure:
Which Mobo u’ve got? Go to the Manufacturers website and download the latest drivers for it..
Also there is another solution u can try. Open IE, go to tools > Windows Update > Use Custom > u will find hardware drivers update on the left hand side, download em of u see any.
