HD Monitor
Is it ppossible to plug my laptop into the HD socket on my TV? There is a PC monotor cable imput which I use, and it seems ok with a resolution of 1024 x 768, with a resonably good picture!!
Interested in any reply!!
phill:ohah: :ohah:
Well, I am not sure if there are VGA to HDTV adapters but if you have an S-Video connector then you can get an adapter.
For what it’s worth I do belive that HDMI and DVI are compatable with each other, assuming you have a HDMI/dvi port on you TV and a VGA to DVI adaptor is possible…
[QUOTE=Exfoliate]
As a matter of interest…
Experience the Power of AI with Windows 11 OS, Computers, & Apps | Microsoft Windows
Beefy yet resonable requirements on 1080p there. So long as you have a really big LCD or 21" CRT.
