Hi, awhile back I pulled my HD out of my main comp and put it into another. I used it like that for about a month or so and now I want to put it back into the computer it was originally in. When I turn the computer on it completes post succesfully then goes to the windows boot screen as normal. About the time when it normally is about to finnish booting windows the loading bar slows down and then I get a BSOD which oddly turns green then yellow, the loading bar is still visible moving through the BSOD. The computer then restarts. The BSOD is only visible for a split second. I know the HD works and I have booted into the comp I am moving to using Linux so I know my hardware is fine. I dunno if you guys need any specs for this problem but Im using an ASUS A8N32 mobo, a Samsung SP1604N 150BG HD, and a Geforce 7800Ko graphics card.
The computer boots into safe mode fine.
a couple of questions,
[ul]
[li]what OS ?
[/li][li]what PSU ?
[/li][/ul]
Im sorry I fixed it right after I posted. Lame; thanks anyways.
Could you post the solution please, to help future users with this problem.
I used systems restore all the way back to May. It mixed up my files horribly and I had to reinstall a bunch of programs but I didnt lose any critical data.
