My recently ordered Saphhire Radeon HD5570 just got here today. I Inserted it into my PCI-E Slot and booted the comp. Nothing appeared on the monitor. I inserted it into another PC to make sure and it worked absolutely fine.
So what seems to be the problem here?
Could be two things, One, is the PCI-E slot turned on in your Bio’s ? Two, the slot on your computer could be burned out..
How do I fix it then?
Whats happens if you go into your bios ? Can you get into your Bios ? If you can,You need to change your settings from onboard to PCIe…
