Headset with microphones
Does anyone reccomend a headset for a computer that has a microphone attached to it? I would like to get one that will have two speakers for both ears. Thanks.
P.S. If it is poratble that is great.
Go to any closesest warehouse and buy any cheaper one if you just wants to use it for Voice Chat with someone. Also, if u have any headphone without Mic then you can use them as a Mic as well. Just insert the headphones jack into the Mic port and speak through it. The Listening will be carried on with your current normal speakers…
NewEgg carries the Sennheiser brand which are the best I have ever used.
They have a whole new line of PC headsets.
